Yes Softronic or any of the other flash tuners will be able to do a tune for you on their dyno's.
My 996 Turbo is flash tuned that way.
I thought the UniChip would be cheap for you, Mine was an old 2nd hand model, but is good enough for my set up. Only thing to do was hot wire it in to the ECU wiring loom.
No need to do injectors they will flow plenty but if your worried about fuel pressure upgrade your fuel pressure regulator to a 5psi FPR from David Green at Green Motorsports over there in the states.
Tell him I sent you and you will get a good deal.
If you have any questions at all I'm more than happy to share my knowledge.
If you haven't done so already I would look at fitting front ant rear strut braces ant the lower brace from pedros garage on the net. Then fit adjustable sways with tarett drop links the improvement in handling it just fitting the above is worth its weight in gold.
Good luck,
Cheers,
Tim
