Old 05-18-2012, 12:53 AM   #21
Steve Tinker
Steve Tinker's Avatar
Why would you use 20W-50 in your engine even in elevated air temperatures - thicker is not always better.
The secret to good lubrication and cooling is oil flow, not viscosity. If oil thickness ( xxW-50) was the secret recipe for hot climates, why wouldn't you put in strait W-50 oil?
The oil flow to the bearings is (generally) dictated by the coolant temperature - lowering the coolant is possibly the best thing you can do for your oil.
In the old days, if you had 10 psi per 1000 rpm @ hot running temperture (never mind the viscosity), you were good to go....
2001 MV Agusta F4.
