Old 05-17-2012, 07:12 AM   #21
ProjectM96
Originally Posted by SoK View Post
How did the water get into the car?
My A/C line is clogged so the water leaks into the car instead of outside the car everytime I use my A/C. Common problem with Boxsters.
In addition, the plastic trim under the car is broken by the mud flap.
If you remove the carpet where it meets the firewall, you would notice some holes that go outside. Since the plastic trim under the car and the plastic mudflap by the rear wheel is broken, water gets into there when it rains making the situation even worse.
When I drive up hill, water starts to flow back out of the large crack in my plastic mud flap.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
