Old 05-17-2012, 06:43 AM   #10
tranceatlantic
Tim986, thats great that you got the system working. I'm really looking forward to installing now I've done some reading but I want to do it right. Thanks for the info on the rebuild kit. Thats a weight off my mind that i won't have to send it in for a rebuild. How many miles have you put on the 986 since the SC? Without upgraded injectors I'm a bit worried it will run lean so I'm going to price some new/remanufactured injectors first. I didnt have any luck finding a UNICHIP setup for less that $2000 USD. I'm interested in knowing if it's possible to just remap the ECU with something like the Softronic package. Since your not running (and I'm also not planning on running) the 7th injector then maybe it's possible to get away with not having a piggy back computer. Couldn't the stock ECU handle it as long it's look-up values for thing like injector pulse were modified?
Also, does anyone have any recommendations for injectors used with and SC running 4-5 psi? What are the stock sizes/flow rates?
tranceatlantic is offline   Reply With Quote
