Old 05-17-2012, 12:00 AM   #1
Kenny Boxster
Moderator
Downshifting from second to first is not good with out A. Rev matching or B. Depressing the clutch all the way effectively rendering the gears in neutral while the stick is engaged in first. It's not bad to drop from second to neutral, you can do so from any gear to neutral with no problem, on the highways I drop from fifth to neutral and let it coast sometimes, then rev the car in neutral to rev match it when I want to get back in gear.
Not to hijack this thread, but does the boxster have a speed limit into shifting into first? I searched and found nothing, it feels that if I am going over 12mph, I cannot shift into first gear, almost the same as trying to shift into reverse while moving, which I know has a mechanism that prevents reversing.
