Maurice's recommendation is definitely ideal. If you can find the full frame and top from a 03 or 04, do it. I'm not sure if there would be some microswitch issues to work out on an 02 versus an older 986, but again, it's worth the effort.
I have a Robbins glass top (basically the same thing as a GAHH), and I think it's great, but I'm comparing it to my original, 15 year old top that was on there. At least with the OEM glass you don't lose nearly as much visibility as you do with the aftermarkets meant to fit on a 3-rib frame. Either way, when you drop the top what size your window is becomes a non-issue.
-O/D
IMSR + RMS
Robbins glass window top
