02, original suspension components, I'd change the other control arm, in fact at that age I'd probably change them as a pair out of the gate. Your id says Ontario, I live in the freeze/thaw region too, think about the pounding the ball joints in that arm every spring on our rutted trails. Most noticeable over bumps is some suspension component, if the steering feels effected check the tie rod ends. One good thing is even if you chase your butt a little at that age replacing these items can only help preserve the performance and longevity of your vehicle.
