Old 05-15-2012, 09:56 PM   #19
magicstick
what size wheel
Originally Posted by ProjectM96 View Post
Well mechanic tried to get alignment as close as possible after installing these springs, but in the end, he could not get it to match factory specs.
Toe is slightly off and camber is off, especially on rear tires where it is visually noticeable.
Are you using stock wheels or after market, sometimes different offset and width will throw off alignment. Also, even factory spec will have certain alignment tolerance. alignment.
magicstick is offline   Reply With Quote
