Old 05-15-2012, 06:38 PM   #22
Steve Tinker
Steve Tinker's Avatar
Theres been lots of opinions regarding metal impellars. Both Jake Raby and John (JFP in PA) recommend the original plastic because if the W/P bearings wear or even collapse, the metal impellers will grind through the alloy crankcase quick smart.... Goodbye engine.
At least with the plastic composite impeller blades, they can break or wear off (just like Spinnakers) and not cause immediate damage.
So Raby may be correct in recommending W/P changeout every 4-5 years. At ~$250 a pump + 3 hours of my time, its cheap isurance.....
2001 MV Agusta F4.
