Old 05-15-2012, 04:05 PM   #20
Spinnaker
Spinnaker's Avatar
Originally Posted by blue2000s View Post
This is the replacement pump that I got from Sunset. Brown plastic.
While I'm not trying to infer that the brown plastic is in some way inferior to the black ones, it was just the most obvious visual difference in appearance, along with the surface texture of the casting, that I noticed between the LASO and the OEM pump. Also, there was no casting number on LASO that both of my pumps had, and I see that yours also has. (red circle) The machining of the gasket surface is also not as smooth and fine on the LASO as it was on the OEM pump.
