Thread: Litronic Issues
Old 05-13-2012, 09:33 AM   #6
brianbiney
BUMP
I'm having a similar issue on my driver's side low beam lamp. I figured it was burnt out so I replaced both low beams with genuine Philips D2S lamps.
Turned on the headlight switch, both work. Great!
Problem is that the drivers side lamp goes off after a while. The passenger side lamp works all the time. I have removed and reseated the drivers side headlight several times nut there has been no change. Works for a while, goes out. No flickering though.
Same problem as OP? Thoughts?
brianbiney is offline   Reply With Quote
