Old 05-13-2012, 07:58 AM   #2
oc-boxster
oc-boxster's Avatar
i am in the same position-just bought an 02 S clutch pedal is very stiff. when i was getting PPI done he said replace clutch asap to avoid flywheel damage i will do IMS and RMS while gearbox is down, im gonna do a slave cylinder too, along with water pump, low temp thermostat and front engine mount which is torn. mine has 82,000 miles
oc-boxster is offline   Reply With Quote
