Stiff clutch / clutch replace q?
Hi am a new member...just got an 03 boxster S. the clutch pedal is quite stiff and I know that means probably good time to replace the clutch. The car has 46k miles or so. I am thinking of the 45k service just to be sure that was done as well as replace clutch.
Here is my q...when I get the clutch replaced should I also upgraded to a L&N bearing and also replace rear main seal? Thoughts? Also is there anything else I should consider like preemptively replacing water pump etc?
Thanks!
Michael
