Old 05-12-2012, 10:54 PM   #1
Mrmaddbrad
Could they be locked in the computer to prevent changes or something?
Ray
No. That's the short answer.
How I tested mine is by of course first testing if it will slide forward and back with the lever in the front of the seat, then tilting it all the way back until it will no longer go, and pulling on the side lever. That lever should make the seat *pop* up slightly. I say slightly but it is very noticeable.
That lever is to change the height of the seat and can be set all the way back down by holding the lever and using your feet to press yourself down towards the ground at about a 45 degree angle between the motor and the street below you, it does take some getting used to.
Good luck!!
Mrmaddbrad is offline   Reply With Quote
