Old 05-10-2012, 05:31 AM   #1
TerryT
2002 Boxster
Originally Posted by ppbon View Post
... to the instrument cluster.
First, the spoiler will go up manually with the one-touch switch on the fusebox, but to lower it you must keep depressing the switch until it lowers completely (it's not one-touch on the way down).
Second, you may have a bad "dinger". Check to see if it's properly connected (over the fusebox - look in your manual for the exact location).
Third, you may have a bad switch on your remote. Check with your other key to see if the trunk opens.
Happy Boxstering,
Pedro
Hi Pedro, I guess my question is not about the individual items listed (and their proposed solutions) but rather "Does the communication for these 3 items run through the instrument cluster" ?
I know the automatic spoiler raising and lowering is controlled by the cluster. ie. The speed hits 75, sends message to spoiler to raise. etc.
But does the cluster tell the dinger that the light is on when I open my door ?
Does the cluster send a message to the trunk to open when I press the remote ?
So if these 3 things are not working it could indicate a bad cluster ?
Terry
TerryT is offline   Reply With Quote
