There are several places where the noise can be from. Easiest and most common is the power steering fluid. Please note there is a special fluid needed.
Another is the top mount bearing on top of your strut, if you hear it to one side or the other. The lower ball joint makes noise too.
If it is a clicking noise then it may be the sway bar end links
