Thread: fuel gauge or?
Old 05-08-2012, 02:13 PM   #4
ppbon
ppbon's Avatar
If you can only put 11 gallons when empty ...
Originally Posted by healthservices View Post
One of the boxsters I have never goes to empty on the gauge but runs out of gas at 1/4 tank. I believe the tank to be reading correct because I can only put 10-11 gals in when empty.
Any insight?
... then the fuel pump was probably dislodged from its base and is "floating".
You'll have to access the tank, which is under the battery.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
