Old 05-07-2012, 01:44 PM   #2
ppbon
ppbon's Avatar
Those things are not related...
Originally Posted by TerryT View Post
1. Rear spoiler doesn't automatically deploy, can be raised manually *but not lowered.
2. No ding when open doors with headlights on.
3. Rear trunk will not open with remote. *but will open with button next to drivers seat.
Could these all be pointing to a bad instrument cluster ?
... to the instrument cluster.
First, the spoiler will go up manually with the one-touch switch on the fusebox, but to lower it you must keep depressing the switch until it lowers completely (it's not one-touch on the way down).
Second, you may have a bad "dinger". Check to see if it's properly connected (over the fusebox - look in your manual for the exact location).
Third, you may have a bad switch on your remote. Check with your other key to see if the trunk opens.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
