Old 05-06-2012, 08:11 PM   #13
Topless
Track rat
Topless's Avatar
Originally Posted by tommy583 View Post
I also forgot to mention that I have a chirping sound upon hitting the gas. It happens more when i let out the clutch ( under load ). If i just hit the gas in neutral ( wife helping ) then it's just a quick chirp, instead of a few chirps. I'm thinking after replacing the belt, I more stress on a pulley or the water pump. Or after searching the threads maybe the tech didn't snug down one of the spark plugs when he replaced them. Could any of this ( Original Post ) loss of power at higher RPM's and Chirping be related?
Yes.
Failing AOS, loose spark plug, and badly worn chain tensioners have been known to make a chirping sound. Your car is a possible candidate for all three.
