Thanks radium
So TPC just buys magneson SCs and then sell them on as a kit for the boxster I take it. I'm a bit confused on a few points. What is the extra bracket for? I have found the spot where the SC will sit and I've tried to imagine how it will all fit together. The 7th injector you mention has me at a loss. I've heard of this configuration being used before but I can't get my head round it. If there is one injector per cylinder where does the 7th go? I assume the mixture needs more fuel than the stock injectors can cope with? But this injector is not injecting into a cylinder right?
The next question i have for you is about the oil. You mentioned a vacuum failure that would send oil to the SC. I'm not sure how as it's a sealed unit. Did I misinterpret and you are referring to a catastrophic oil failure?
As you can probably tell I'll feeling like I've bitten off more than I can chew here but I'm willing to see this through, at least at this point.
So whats your connection with radium if you don't mind me asking?
