Old 05-06-2012, 05:45 PM   #5
tranceatlantic
Thanks radium
So TPC just buys magneson SCs and then sell them on as a kit for the boxster I take it. I'm a bit confused on a few points. What is the extra bracket for? I have found the spot where the SC will sit and I've tried to imagine how it will all fit together. The 7th injector you mention has me at a loss. I've heard of this configuration being used before but I can't get my head round it. If there is one injector per cylinder where does the 7th go? I assume the mixture needs more fuel than the stock injectors can cope with? But this injector is not injecting into a cylinder right?
The next question i have for you is about the oil. You mentioned a vacuum failure that would send oil to the SC. I'm not sure how as it's a sealed unit. Did I misinterpret and you are referring to a catastrophic oil failure?
As you can probably tell I'll feeling like I've bitten off more than I can chew here but I'm willing to see this through, at least at this point.
So whats your connection with radium if you don't mind me asking?
tranceatlantic is offline   Reply With Quote
