Old 05-06-2012, 03:09 PM   #4
The Radium King
The Radium King's Avatar
it's not custom, it's a kit by tpc (check the sc build thread on this site). if everything you get is in the pictures then it's missing one of the mounting brackets; tpc can fabricate you a new one. also, it's designed to work with a 7th injector which means you need a piggyback computer to operate it. tpc may be able to provide you one. if you want to do a tune instead you'll have to remove the 7th injector and put larger injectors in the stock positions. softronic should be able to do the tune for you. if you seach this site you'll also find that brad roberts has dealt with a lot of these as apparently the mounting position starves the sc of oil; regardless, you should send the unit out to be refurbished. you'll probably also want to put in the latest edition of the aos in your car, as the unit draws vacuum from before the sc. so failing aos will send a whole lot of oil through the sc. you'll also want to think about fabbing a heat shield or wrapping/coating your headers, as the sc sits right close to them. if you want your engine to last you might also want to think about fitting an intercooler in there someplace, otherwise you're slamming hot air into an engine with poor air/fuel control given the 7th injector design - boom.
