Old 05-05-2012, 09:20 AM   #10
bar10dah
bar10dah's Avatar
Originally Posted by blinkwatt View Post
~Top Speed the company that basically stole B & M's design, installed the shaft backwards. Simple fix,just remove the nut and flip it and TADA it's the same as B & M!
When sitting in the car, which way "should" the shifter be leaning to match the B&M? The way the TS SSK was sent to me, it's leaning towards the left. And, the stock shifter coming out is leaning towards the right. So I swapped the TS SSK to match.
What kind of lube should I use when reassembling?
bar10dah is offline   Reply With Quote
