Old 05-03-2012, 08:58 PM   #1
ojjuan
wiring 6 pole kill switch
i am installing a 6 pole kill switch on my spbox and to be clear, i am no guru when it comes to auto electronics. anyway, i know how to connect the battery, main feed (to two poles) and the resistor. however, the instructions that i have say to cut the wire from the ignition to the ignition coil and attach to the two remaining poles. however, i'm not sure where this wire is. Is it the ignition lock wire that runs through the center tub from the high amp fuse box?
any help would be appreciated!
i am using a switch similar to this
ojjuan is offline   Reply With Quote
