Old 05-01-2012, 03:31 PM   #2
Bala
Is it front or back?
Once the top nut is removed the plate should come off and then the entire spring can be taken out. Did you compress the spring with the tool? If not do a little bit. then tap the top plate out slowly. Make sure the tool is seated well.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
