Old 04-30-2012, 07:09 PM   #1
m332is
Window/top issue
I posted this on Pelican bit got responses so I thought i try a cross post... I have a new issue... when I unlatch the top, the windows no longer drop however if I manually lower them, they go up when I re-latch the top. Here is what I have done so far:
2001 Boxster S with 15,000 miles
Disconnected the battery, waited 10-15 min and reconnected it. No changed.
Bought (from Pelican) a new micro switch that goes between the sun visors. After replacing the micro switch I get the same result. Windows don't drop when unlatched however they do go up when latched.
If I depress the window switches, the windows will go full up or full down properly.
I am open to suggestions or ideas.
Vince
m332is is offline   Reply With Quote
