If nobody has a definitive answer, here's a couple of ways to figure it out.
Ask the seller what the measurement is from the point where the wheel contacts the hub to the outside edge and the inside edge of the rim. Measure the same on your wheels and make sure the spacers make the inside clearance the same and don't cause the wheel to be outside the wheel well.
Another way is to wait until you get them, then put washers on until they fit right then measure the thickness of the washers you end up with.
Nice looking wheels!!
1966 Wife White/Brown Top
