Old 04-27-2012, 01:04 PM   #5
David Wildrick
Originally Posted by boxster6354 View Post
I wonder if they upgraded your Ignition Lock Housing to the newer 2004 version also when you had the issue under warranty?
It could be. I didn't look for the paperwork on the warranty job.
If they did change to the newer version, I guess it means there wasn't a big improvement in failure rate of the "improved" switch over the old one. I'll let you know what happens.
David Wildrick is offline   Reply With Quote
