My understanding is this hack will illuminate low beams at full brightness. The headlight switch would activate all other exterior lights & dashboard. Fuse 9 is low beam, you could look up the high beam fuse and jump to that... only problem there might be heat buildup in headlight housing.
This gets used as a low-buck DRL activation on US cars imported to Canada, otherwise expensive electrical additions are required to certify for road use in the Great White North (eh).
