Thread: DRL Hack
Old 04-25-2012, 03:21 PM   #2
BoxsterSteve
still plays with cars...
BoxsterSteve's Avatar
Locate the fuse box cover on the lower left side underneath the dash, remove the cover and locate fuse number A6 and A9, both fuses are located on the first top row, from left to right fuse #6 and fuse #9, if you don’t have heated seats the #6 fuse slot will be empty.
Once located, you will need to have a 3 inch long electrical wire (18 gauge wire is good) strip each end of the wire approx. ½” on each end of the wire, what you need to do is use that 3” wire to jump fuse #6 and #9 like a bridge, take one end of the wire and wrap it around one peg of the fuse and the other end on one peg of the other fuse and insert both fuses back into their respective slots #6 and #9.
If you had an empty slot, simply use a spare fuse, amperage not important, in the empty slot. Verify that the hack worked by putting the ignition key on the headlights should come on.
I removed the DRL module on my Canadian spec car and tried it. It does indeed work.
