Supercharger Fix
Best thing for you to do is get a
unichip and have it Dyno Tuned.
I have the same set up I dont use the 5th injector anymore its not required if you fit a UNICHIP.
I fitted a 5bar Fuel Pressure Regulator and dyno tuned with the UNICHIP and now have 180kw at the wheels which is not bad for a little 2.5lt Boxster main problem with the TPC kit is the restriction where the boost pipe is squashed to fit in the engine bay.
I love my little boxster I'm currently in the process of rebuilding it.
I also have a tuned 996 Turbo with 628ft/lbs and 400hp atw and I'm sure I can drive the Boxster faster in the mountains for driving on the twisty stuff you really cant beat the boxster.
