Old 04-22-2012, 03:24 PM   #2
santambrogio
Sir 9025
Spend the $36 and buy the Sir 9025 set, you will be able to fix this problem, as well as any other similar issue on any car you will ever own in the future...............
I did buy the SIR 9025 12 piece tool and the 1.6 twin blade tool that fit the blue AMP connector to the headlight body did not unlock the pin connectors.
I am looking at other kits unfortunately for more $$.
I do not think that I am using the wrong tip but that I need one with thicker blades.
santambrogio is offline   Reply With Quote
