Sticky Clutch - Help With Parts on Clutch Slave & Master Cylinder
Hi,
I'm having issues with a sticky clutch. Took the car to an independent shop, and was told it's the slave. He also said the spring inside the master is failing so he recommended the replacement on both parts. Doing some research at home for the best parts, and the best prices.
I'm looking for OEM, can you guys look at this order before I process it. I want to make sure I'm ordering the right parts. Also anyone know the OEM parts number for both the Slave and Master Cylinder? It's for a 2002 Porsche 986 Boxster S!
