Old 04-20-2012, 11:10 PM   #13
fivepointnine
Originally Posted by ohhh my View Post
I have a similar problem which only occurs BEFORE the car gets to operating temp. Once it reaches operating temp, shifting into 2nd is buttery smooth. But before it reaches temp, if i want to use 2nd gear, I just have to pull a little bit harder to keep it in 2nd and it never pops out if I use a little bit of muscle.
Thoughts on this?
mine does it on the first shift or 2 of the day when its cold, but it does not pop out in the traditional sense, you just have to hold it when you let the clutch out, its weird...once it is in gear for the first time you can drive it around in 2nd without issue, I have been babying 2nd since I have noticed the issue, hoping it does not get worse!
fivepointnine is offline   Reply With Quote
