Old 04-16-2012, 10:58 PM   #2
sb01box
Originally Posted by trygve View Post
I'm not sure, but I think I found an error in the Durametric software's Motronic fault code reporting. I was getting a pair of codes on a fairly regular basis. I think they happened together. As reported by Durametric 5.1.40 for my 1998 986:
P1121 Porsche fault code 430 - Throttle position sensor 1
P0160 Porsche fault code 20 - O2 sensor behind cat. conv.
But while scouring the web for possible solutions, I found a page that listed code 1121 not as a throttle position sensor error, but rather this for the pair:
P1121 Oxygen Sensor Heating 2 After Catalytic Converter - Below Lower Limit
P0160 Oxygen Sensor After Catalytic Converter (Cylinders 4 - 6) - Interruption of Signal
Now that makes more sense--nothing to do with the throttle position sensor if that's correct. All about the post-cat O2 sensor. I've replaced the sensor and await a hundred or so miles of CEL-free driving so that I can pass a smog test!
Here's the page with the info. The author is Randall who I think might be a frequenter of 986forum.
Boxster Check Engine Light Codes
the first set appears to be for DME5.2.2 and the second set is from DME 7.2 .
based on Bentley manual.
don't know when the transition took place, but isn't the 5.2for the mechanical throttle body whereas the DME 7.2 is for the electronic throttle body cars?
sb01box is offline   Reply With Quote
