Thread: Rear Alignment
Old 04-15-2012, 03:03 AM   #4
san rensho
Its not out of spec. Standard alignment calls for a lot of negative camber which will cause the rears to wear on the inside. If you have directional tires, the fix is to dismount the rear tires and re-mount them on the opposite side. You can't do this if you have assymetrical tires. I just did this and it cost less than $75.
Another fix is to alter the alignment and get as much negative camber as you can in the fronts, and set the rear camber close to zero. This will take out a lot of the understeer that is designed into these cars which will make the car handle much quicker, but you won't have the cushion of understeer if you get in trouble going around corners.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
