Old 04-13-2012, 06:18 AM   #10
harryrcb
Crazy Austrian
harryrcb's Avatar
Originally Posted by Brad Roberts View Post
I have seen NO 2.5 failures. Doesn't mean it won't/cant happen, but I have seen none and I have been involved with the cars since 1999, racing/time trial/autoX since late 04. The 2.5 doesn't turn the RPM that the 2.7/3.2/3.4 turn, it doesn't see the same heat etc.
I have pulled apart a LOT (20+) blown 2.5's, a couple had questionable bearings, but none of them had failed completely.
B
Brad I have a 2.5 now that has jumped timing but I have not pulled the bearings out to see if that was the cause. I retimed the engine but one of the cylinders has low compression. comming out the bottom end that's why I did not bother with the IMS. Now, however, I will have to pull the bearing to see it that was the cause. Will let you guys now end of next week
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
