So after buying my 2002 Boxster S, I quickly realized that both keys I was given do not unlock the doors wirelessly although they will unlock the car manually.
Lets list some stuff that does and does not work:
-Both Keys manually unlock the doors
-Both keys will start the car
-The central locking button inside the car unlocks, and locks the car
-When locked, the doors unlock when the handle is pulled on from inside. (but not outside of course)
-The LED on both keys flash.
-Both key batteries are new.
-When started, the ignition switch must be manually clicked back to the second or "run" position (sticks in the "start" or third position), before the accessories in the car work. (AKA Needs an Igniton Switch)
-The driver's side door window "tilt" function does not work.
-And of course, both keys will not lock, unlock, or open either trunk.
Some one come save me
I don't wont to have to buy a Key if I don't need one. And I can't seem to find a way to test the keys or the receiver in the car. Heck, i can't even find what module actually receives the signal from the key.
~Brad
