Old 04-12-2012, 10:37 AM   #6
Johnny Danger
Johnny Danger's Avatar
Originally Posted by 3point2 View Post
Thanks Johnny for the reply!
From your recommendation, the rear offset is ok. For the front, would a 10-12mm spacer need extended lugs?
I was reading other threads and it seems like most people are running 265/35/18 in the rear. Is this a better combination with the front 225 wide tire?
Yes, you will definitely need longer lugs bolts . Keep this equation in mind:
oem standard lug bolt length 28 mm's + the size (meaning thickness) of the spacer = the length of the lug bolt needed . As far as tires are concerned, in my opinion, 225 & 265 would make for a better balance .
