Originally Posted by 3point2
I've been looking around for a used set of Porsche 18" twist wheels and tires lately that I would like to put on my 03 S. But there are a slew of different sizes I've been running into. So now I'm sort of confused
What is the most optimal size 18" twist wheels and tires I should be looking for? I will be lowering the car with Eibach or H&R springs eventually.
- Front and rear wheel widths?
- Front and rear offsets?
- Front and rear tire sizes?
- What front and rear spacers needed (if necessary) to make the wheel/tire flush with the fender?
Thanks for the replies.
Simply put, based on your choice of wheels, the lower the offset, the better the fitment will be for your vehicle . If you're beholden to the turbo twist wheel, the following guidelines may help you decide on how to augment the fitment .
8 X 18 - bringing the offset down to around +40 or so will likely give you the look that you are going for .
10 x 18 - bring the offset down to at least +45 to 40 will achieve the same .
