Maurice...all good points and thank you! Took her out for a spin at triple speeds on a less then smooth highway (good bumps) and there was not a hint of movement. Additionally, Pothole is correct...the clam shell does lock the top down as you are not able to lift the top up when it is held in place by the transmission which is why I wanted to keep the clam shell on the motor. Now...if the clam shell was not attached, yes you could have a very bad day based on the clam and top bouncing in the "perfect storm" setting.
Like any of the mods we do, you have to be first be comfortable with what you are doing; second accept the risks that may or may not come with said mods. I rate this mod based on my set up a "solid" on the comfortable factor and "low" on the risk factor.
