Old 10-20-2005, 10:52 PM   #2
MNBoxster
Originally Posted by bmussatti
Has anyone used a product called "Tire Cradle"? These are apparently very high density polyurethane polymer pads to park your car on to prevent flat spotting, especially for long storage periods (winter storage). They are quite expensive too, about $350 for a set of 4.
Hi,
Flatspotting isn't as much of a problem as it was in the past. This is because Kevlar has replaced Steel as the preferred Belting for a Tire. It has much less memory than Steel. The Tire cradles are OK and probably do the job, but they are half the price of a set of tires! If you inflate your tires to 58PSI when stored (as Porsche recommends), you'll pretty much avoid the issue altogether. Hope this helps...
Happy Motoring!...Jim'99
