					Originally Posted by  Kianfar
				 Interesting, that it put 1,2,3,4,5,6 between the 3000-3500 range. Wondering if that's the optimal best shift area.
I would not read that into the chart -- it is just a label identifying which line corresponds to each gear, and that location was fairly centered.  I believe the optimal shift point depends on how you're driving -- for maximum acceleration, the optimal point is
significantly higher than that.  for everyday driving, that's probably not far off from where I shift (although I think I run it up a bit higher).
