Old 04-10-2012, 09:07 AM   #13
papasmurf
I've had the TP shifter in my
car for about 3.5 years now. In the beginning it was very mechanical and "notchy" which I was fine with. The throws were noticeably shorter. It has over the past year gotten really sloppy with alot of side to side movement. I wound up having to rig some plastic shims to fill the gaps in the shift linkage which were causing the wobbling. That helped alot but it seems the part it three fold....some of the slop is in a slight gap between the shift lever and where it mounts to the short shifter base (bolt goes through it)....some of the slop is where the pivot ball mounts inside the square assembly the connects to the shift linkage....and some of the slop is in the shift linkage cable themselves as they can move slightly side to side. FWIW I think personally the B&M is pretty much the same shifter and would not spend the money to purchase one.
papasmurf is online now   Reply With Quote
