Old 04-10-2012, 01:23 AM   #22
benr999
I might have to get a set of this now. yeah, I thought +35 on the rear seemed very aggressive as well. I was playing with the wheel offset calculator and was thinking of using the following setup to extend both wheels out 27mm (~1.06") so front and rear will be even (inside wheels will consequently extend +11mm from my stock 17").
Front: 18x8.5 +47, Rear:18x10 +40
So will the above work and does +27mm that extends outer wheel position will look "flush" enough without looking too aggressive (or do I have more room). Is it a good idea to make both front and rear tires extend the same clearance this way.
Wheel Offset Calculator for my front wheel:
benr999 is offline   Reply With Quote
