Old 04-09-2012, 06:07 PM   #3
2003S
2003S's Avatar
1) run, don't walk away
2) the vinyl wrap is most likely covering a paint job in bad shape, so add that to the other 'concerns'
3) if you don't run away, do not even consider buying this car without a PPI -- a PPI from an independent shop is ALWAYS useful when buying; a couple hundred dollars could save you thousands ($9K in this case)
2003 Midnight Blue S
LN IMS Retrofit
