Thread: At Wit's End
Old 04-06-2012, 05:16 PM   #1
sb01box
The symptoms are: 1) car throws codes P0410 and P1411 as soon as the secondary air monitoring system kicks back in after a CEL reset, 2) engine hunts for idle between 600 and 1000 rpm after coming up to operating temperature, and 3) remote key operates unpredictably.
all ties together as engine intake/exhaust/cat/O2 but the unpredictable remote key does not.
but if you assume the electrical to be the root cause, remote key also ties in.
I would check the battery. volt meter in DC and AC.
sb01box is offline   Reply With Quote
