Old 04-01-2012, 02:37 PM   #11
JNC
Originally Posted by Kirk View Post
My solution... I ran a jumper wire in the wiring harness that feeds the lights between the brake light and the fog light. Now my fog lights (red LEDs) also come on with the brake lights.
Kirk
Kirk, I did the same as you above with my Boxster DEPO LEDs, and both the brake LEDs light and the LED fog lights came on first time I braked (ie worked as planned). Since then, only the brake LED lights work when I brake. I checked the fog LEDs via lil rewiring, to make sure they still work, and they do, but not together with my brake light. My son suggested maybe a voltage or amperage issue for both to turn on together powered by only 1 socket (brake socket). If so, think anything internal blew since first try?
This is the second set of DEPOs I've had....With my first set, all 4 LED sets on both tail lights worked for a while when I braked, then the fog light on the passenger side stopped working with the brake light (driver's side tail powered both brake & fog LEDs).
Any suggestions? Thx in advance! I believe these sets to be made with cheap electronics but they do look nice when you can get all 4 sets of LEDs work when braking.
JNC is offline   Reply With Quote
