Put it up on the rack today and checked it out. I couldn't feel any play in the steering rack, so they must of tried something that I didn't.
I was wrong about the front strut rod bushings, I misunderstood the mechanic. The part that I need to replace is the bushing in the 'diagonal control arm' (according to my bentley book). The mechanic and auto parts calls it a 'strut rod arm' though which is where I got confused.
The bushing circled in red is the one needing replacement
Finally found the part number for the whole arm - 996-341-043-06
Is it possible to just replace the bushing, or does the whole arm need to be replaced?
Originally Posted by Bala
Do it yourself and save the labor money for other parts that require attention.
Yeah, I am planning on doing it all myself except for the tires. I've done all these repairs on other vehicles, including a rack/pinion, and from reading, I'm confident I can do them, once I get the money for the parts that is.
Originally Posted by Spinnaker
Do a search for wheel repair/straightening. Lots of places that can fix a bent rim if it isn't too bad.
The bent rim isn't too bad, I must of hit a curb at some point, it's not on the edge of the rim but in the middle, I can see it only when spinning the tire.
