					Originally Posted by  The Radium King
				ok, how about interfacing it with a lateral-g sensor? reduced boost when the car is pushing sideways ...
I don't know.  This might result in the same thing as a "lift throttle" mid corner, inducing a spin.  The basic rule with a 930 or 951 is:  When the car comes on boost, make sure your steering wheel is pointed straight... even if you are mid-corner make sure the wheel is pointed straight.
If it was my car being built, I would favor a wider, fatter powerband and give up some top end HP in favor of drivability.  A 997TT is really pretty good here and any turbo motor could be tuned for drivability.  Everything is a tradeoff.
